Introducing Sertain: A framework that makes programming robots easy-peasy!
Hi everyone! I’m Aidan, and I’m part of team 2521 SERT.
I’m going to get straight to the point: programming is hard. SERT 2521 has spent the past 6 months developing and testing a new framework called sertain (get it? it’s a pun!). Anyway, sertain takes a new approach to robot programming. Using the language features of kotlin, sertain allows you to construct robot programs in a simple and intuitive way, making programming robots the way it should be. Take a look here.
Be absolutely SERTain that your robot works! (thats a pun to geez we should stop)
PS: Sertain is not done being developed, however it is ready for use and can be use to create a beautiful codebase for your robot.
Also PS: Sertain would not exist if it weren’t for team 2471’s meanlib. While sertain is really different from meanlib in a lot of ways, some of it’s core aspects are inspired by meanlib. It’s a really great framework, check it out!
Also also PS: We made a version of sertain before. This sertain is completely different and frankly has nothing to do with the other sertain. We just like the name :sweat_smile:
What is the advantage of using your subsystem and event framework as opposed to the WPILib command based framework?
For one thing, it’s less work. Commands in WPILib require you to create an entire class just to run what is basically just a function. In sertain, it is a function.
Additionally, sertain’s subsystem framework makes it so that accidentally using a subsystem is impossible. In WPILib it is easy to forget to require a subsystem. Assuming you are using add to store subsystems, the only way to get a subsystem is to either call use inside a subsystem or to call access for safe access.
Meanlib actually takes a pretty similar approach to this.
The new 2020 WPILib has completely-rewritten the command-based framework. Small commands can now be defined in-line, which is about as short as it can get. I’m interested by sertain, but I don’t know if it’s as warranted as perhaps it once was.
Edit: this is just a response to Jamdan’s justifications for using sertain.
Yeah, the new framework looks a lot better.
However, the framework still allows for error because you need to pass in all the required subsystems to the InstantCommand. Also it’s still less concise. Basically it’s this:
InstantCommand(subsystem::someCommand, subsystem)
versus this:
someCommand()
A small difference, but in my opinion a framework should strive to make things as concise as possible :sweat_smile:
