Stripped down Parameters file included for easy integration of the profile into another file. just import the parameters, copy the initial sketch over, break the fix to origin if it’s needed to be centered elsewhere and then fix the sketch dimension relationships that will drop in the transfer (just have the original file open and copy paste). Pattern using the NumTeeth Parameter and you’re set.
