I’m trying to learn how to use Inventor, I did most of the tutorials, but I can’t figure out how to cut the rail for the robot that i found on the Internet, can anyone help me? I don’t know it I’m using the wrong file or just don’t know what tool to use.
If the rail is an feature that is extruded along its length, you can right click that extruded feature in the browser bar and select “edit feature” to change the length. Or. You can make a new sketch on one end of this rail, and then “extrude cut” back however far you want. Or you could sketch on the side of it however much you want to take out, and “extrude cut” that away.
Or, if you are trying to cut on an angle, make a work plane (defined by three points usually) that is at the right angle and use ‘Split’. Select the work plane and then select that you want to remove a side. Select all of the many faces that are involved and click OK. If the wrong side is removed, edit the feature and click the button that has 2 arrows going in opposite directions (this icon reverses the direction of a selection in almost anything).
Hey,
I tried to use the extrude tool, but is there was an error message that said, “No Unconsumed Visible Sketches.” What can i do to extrude, or was the not what u were talking about. Also when i try to make a work axis, it puts up a message that says, “Work Plane3: Could not build this Plane by three points.” Maybe the problem is that I’m not using the right kind of file, or I’m completely confused. Any help you can give would be appreciated.
Either make a new sketch of the area you want to “cut away” or you can (in the browser bar) right click on a particular sketch and chose “share sketch” Then you should not get the no unconsumed sketches error.
But even before all that, is the current part an extruded feature? If so, have you tried just editing the length of that extrusion?
Hey,
I finally figured out what you were trying to say, but when i try to use the general dimension tool, it says, “Cannot constrain or dimension reference or fixed geometry” what am i doing wrong?
I’m assuming you put a new sketch on a face. If you did it on the end, celebrate, because all you have to do is go to part features, click on extrude, click on the picture that indicates cutting away (it’s the middle one), enter the distance you want to extrude, and you’re done.
If you are doing it from the side, it’s a little more complex but it isn’t all that bad. On your new sketch, make a line that is coincident (touches) the top and bottom of what you want to extrude. Make sure the line is paralell to the end of the piece (or perpendicular to the lines it touches, it’s the same thing). Then click on general dimension, and click on your new line (the green one) and the end of the piece that you want to extrude. On the dimension, enter the distance that you want to cut the piece back, and go to extrude. It will ask you to click a profile, so click what you want to extrude away. Click on the thing to extrude the piece away, and where the thing that says distance is, click on the arrow to the right of it and change it to all.
Inventor is saying that you can’t dimention some part that is already made. You are probably making a sketch on a face of an already extruded part. That face’s geometry is now part of the sketch, but you can’t change the dimentions of it in you current sketch. If the part is the wrong size, you need to go to it’s sketch that you made it from to change it.
One thing you have to remember is that Inventor is what they call Parametric Modeling. This is a fancy term to say that every dimention is related to the others. If you make an extrution and then make another extrution the same shape as the first, then edit the first one, the second one will change. That isn’t the only example, but is easy to understand. Also, if you want an object to be always square, no mater what size, you can tell one dimention on a rectangle to be whatever the other one is.
When you dimention something in a sketch, you are really telling it the size it needs to be. AutoCAD tells you how long something is. Inventor tells you how long something is and wants you to change it. To do the same thing in AutoCAD, you have to remake a part.
The power come from, aparently, a huge database of dimentions and other things you have made. Our chassis model is in an assembly and has about 600 dimentions, including constraints, which are dimentions of a different type.
Hey,
Does anyone know where i can get 35 gear chain for Inventor, or are we not expected to use chain? If we are expected to use how would we go about using the placing the chain on the gears. Also does anyone know where i can get all of the components for the 2005 first 8 inch wheel?
Exactly how would i make a pyramid shape? …half sphere shape?
I’ve been trying to make one for… uh… a while. It’s beginning to frustrate me! :mad: I have been looking through all of the options and tutorials… (or so it seems) … so, any help would be greatly appreciated.
-FOR AIUR!!!
P.S. how do i get my signature picture to actually show up!?!?! :yikes:
If you know all of the angles involved and the lengths of the sides, you can do it. Make a sketch of a triangle (I’m assuming that you mean the Tetras). Make sure the angles and lengths are right using constraints. Finish the sketch and extrude to a good heigth. then use taper to narrow it down. Enter the angle and you should be good to go. This is, howerever, a long path and there might be a better one.
this one is for all those who have the skillz to make the team logos!
i came up with this one not too long ago, i decided to make our team logo ON inventor! could be tricky, but the end result wouls be really cool looking!-
and what about the getting the pictures on the signature???
For a half sphere in Inventor, there are multiple ways to do it. On your sketch, you want to make a line (length doesn’t matter as long as it intersects the arc that you are about to make). Then, make an arc with the radius that you want (ends up being the radius of the sphere). Make sure the center of the arc is coincident to the line.
There are several ways to go here:
Revolve the sketch you just made. I believe there is an option somewhere to tell it how far to go around and then enter 180 degrees. If this works, then great! You’re done. If not, darn, but there is another way.
Revolve the sketch, and let it revolve all the way. Share the sketch that you made earlier, and make sure it is visible. Then click on extrude; make sure the area between the arc and the line is highlighted. Where it says distance, click the arrow and change it to all. Below that, there should be pictures of planes with arrows coming out of them. Click the one that has an arrow coming out of both sides. Make sure you are extruding away the piece, and click OK. Congrats, you’re done!
to make a tetra-shaped pyramid, one could possibly draw four triangles - one equilateral on the bottom for the bottom, and three on the sides of the bottom at 90 degrees to it that are the vertical length and width of the sides. Extrude the bottom, say, 50 inches, and then extrude the sketches with the intersect option and through all selected (or specify a distance, I don’t have inventor in fromt of me right now and can’t remember.) I think that this will work.
This soulds easy, but might make more problems. Unless you know the exact shape of the other triangles in projection, you will get a bad shape. The side triangles are equalitateral but not if you look at the from the side. The would be squashed triangles.
I figured out how to cut a rail for the robot, but i accidentally messed up the file that had it cut to size, now all i have is the smaller piece, now i want to make it to make it longer again, but when i do, the holes that in it every inch or so don’t continue, the extension is just a plain rail ( no holes, can i extend them with holes?
Also when i try to go to the base file (unaltered) and i try to “Move Face” or “Extend or Contract body” it says the following:
Modeling failure in ASM. Redefine inputs.
Faces(s) could not be moved.
Does anyone know how to do either of these, whichever is easier?
How did you cut the peice? if you cut it with Split, then you just move the cutting plane to where you want it and it should update. Especially if you made the holes first. if you did a cut extrution, then you can change the sketch and it will probably update. If you did something different or theses don’t work, then you can look at the sketch with the holes and copy the holes after you extend it. Still lacking? then you can do a rectangular array of the holes. select the hole’s feature, select rectangular array (should be near the circualar aray and mirror tools) and select a line that goes in the direction that you want. set the number of holes and the distance between them and click OK. Or, if all else fails, you can make the holes manually.
With the assembly, it is probably complaining becuase there was a constraint or other setting. First try the Repair tool and follow the prompt to try and fix it. If not, ou can right click on the offending componate and say Re-Place componate. this will reset the file link and posably fix the problem. Or you could delete the componate and place it again.
