Inventor problems
Riiighht… So how do i unconfuse inventor when it freaks out because i moved an assembly and associated files from one computer to another? At least i think that’s the problem. Anyway, i moved some filez from one computer to another and now whenever i try to open any of them, I get a message “error in reading RSe streamer segment.” :ahh: Uhhh… How do i fix this?? :confused:
Did you move the part with the assembly file too? I’ve never had any problems with Moving files.
yep, all the parts are there. I know that’s not the problem bc i can’t even open the individual part files. Same message.
Same Inventor Version I’m assuming?
I know they are both 5.x. I’m not sure about subversion.
-------------------------- Edit --------------------------
Grrr… After some googling, it seems that this is the error you get when you try to open files from diff versions. I guess subversions do matter. I’m not sure i completely trust that though. If that were true then how come the files from flaces like csbliss and First Cad Library work fine for me. Are they saved in a really early version format or something?
Grrr… Anybody have a .ipt to .step converter?
Why not 7?
Well I took ot home over the weekend, but never found time to load it. 7 will come soon.
Note: read edited post above.
That error message sounds like an Inventor version problem. Even within a major rev, you may have problems, such as between 5.0 and 5.3, in my experience.
We also had a similar problem…we had to make project files to transfer files between computers or the computer would get confused.
-Pat
