Inventor Wire Problem
Hey all. I’m in the process of wiring our robot up in inventor and I have a problem. Is there anyway to make the pins and yellow lines invisible in the harness drawing. For wires/segments I’ve already created, it gets quite annoying. Someone help! Thanks! :slight_smile:
Josh,
Not sure that this is what you are trying to do, but have your tried using different layers to control visibility?
It’s been a while since I’ve done this…can you turn it off in the View menu under object visibility?
As far as the Pins go visibility is your best bet but the yellow lines should go away when you route the wire
this is a great refrence tool if you need it
http://www.chiefdelphi.com/forums/showthread.php?t=64206
