Inventor
How do you constraint the chain to sprokets
This has been asked so many times on here. Use the search tool and I am sure you will find a way. I don’t really know myself, because I have found it to be too tedious to be worth it.
FYI: When it has been discussed in the past it involved a long complicated method. If you are not a true expert at CAD, I would not suggest you try it. Seeing as you are probably going to try it anyways, Good Luck.
