inverse sine FPGA
I’m implementing inverse sine inside the FPGA VI. To do that, I use lookup table/LUT. I found the attached VI. I’m just wondering if there’s a way that I could be the one to set the input values in the LUT? In the attached VI, the input value is between 0-1023 which is the ‘address’. Is there a way that I could customize LUT for the input value (i.e. input values could be: -1, 0.8, 0.6… not necessarily the address which is 0,1,…1023)? It’s because I’m having a hard time utilizing the attached VI in mapping the input and output to their true values (i.e. -1 to 1 for input, -pi/2 to pi/2 for output). Thank you very much for your time!
asin LUT.vi (24.9 KB)
I am confused why you are using a look up table. There is an arc sine function built into LabVIEW. You can find in the Functions Pallet group -> Mathematics -> Elementary & Special Functions -> Trigonometric -> asin
I modified and attached your vi with the asin function in it. If you need to shift the value or do a unit change, you can do it to the output of the asin function.
asin LUT.vi (25.3 KB)
I’ll answer your lookup table question, even though I too wonder why you are doing this.
For indices from 0 to 1022, populate your table with arcsine(index/511-1).
To use the table to find arcsine(X) (where -1<=X<=+1), calculate the index as 511*(X+1) and look up the arcsine for that index in the table.
The built-in asin function cannot be implemented inside FPGA VI. That’s why LUT is necessary. :slight_smile:
Hi, Sir! :smiley: Thanks for giving me an idea! :smiley: I’ve successfully created the LUT for the inverse sine! :smiley: Thank you very much again! :smiley: Btw, the questions I’ve posted in the forums are for my thesis :smiley: Thanks for all the help! :smiley:
