Invetner 08 - Gears
I’ve been working with Inventor 08 for a couple of months and I’ve found on the Design Accelerator that whenever I try to make a gear it comes out with a gear a completely different size than I thought was going to come out. Is there any way to fix that? If not is there anywhere I can download pre-made gears to use of various sizes?
SDP-SI and Firstcadlibrary are both places I go to for gears often.
SDP-SI sometimes only has a few teeth modeled, but usually some cuts and rotates will get you a complete gear.
IGear from firstcadlibrary. You can edit some details to make it the gear you want. Here is a link: http://www.firstcadlibrary.com/drawings/inventor/i-SpurGear(English).zip
thanks, Vivek
