IP addresses
Okay, I’ve been working on setting IP addresses so I can start testing things out, but I seem to have a problem when it comes to setting the IP address on the Wireless Bridge. Could anyone tell me how you are supposed to “navigate to the IP of the bridge”?
All help appreciated!
~CHSboy
The default IP of the bridge is 192.168.1.250
You should just be able to type that into the address bar of your browser if you haven’t changed anything.
But i’m just echoing the manual. I’m not sure if you’ve already read it, but you can check out section 5.6.1 of
http://usfirst.org/uploadedFiles/5-FRC_Control_System-Configuration-0-5c.pdf
for more info
Oh, okay. I didn’t realize you just had to type it into the address bar. Hopefully it’s smooth sailing from there then.
