IR Beam Troubles
Has anyone got the IR Photoswitch beams working? We tried wiring them up but got a .01V signal.
We do have it running on 12v power.
did u connect a pullup resistor ???
the output is o.c u know…
Translation:
Did you connect a pull up resistor? The output is “open collector”.
“Open collector” means that it is essentially a contact closure to ground, not a logic-level voltage. It should work fine when connected to a digital input on the RC, because a contact closure to ground is exactly what the RC expects (it does provide pullups on its inputs).
