I was just wondering if you can press fit 4mm broached gears on the bag motor? it doesn’t have the ribs that the rs 775, am-912, etc. have so I was wondering if the gears would slip. I’ve never used a bag motor but I haven’t seen them used outside of versaplanetary gearboxes which seem to use a coupler to attach them.
(I would have posted this in motors but that subforum seems dead)
Thanks, Luke
cool, I thought I was going crazy when he said bag motors have a keyway. Have you tried press fitting a gear to a bag motor or are you just saying it’s theoretically possible?
I have pressed gears on smooth shaft motors before but not a bag motor. My favorite way is to freeze the motor and heat up the gear. It will then slip right on.
