Hello,
I went to a talk/seminar on LabView. The rep from NI mentioned there was a pre-built/default program that rookie teams can use. (It has a big “finish” button on the front panel). Did I misunderstand him or is this located somewhere? If so, where do I find it?
That’s the default Framework that comes with the LabVIEW installation.
Start LabVIEW
Under “New” select FRC cRIO Robot Project
In the popup window give it a new name
Change the cRIO IP address to match your team number
Select Robot Framework
Select Finish
and you’ll have your default project that does Arcade drive off one joystick and two motor controllers plugged into PWM 1 & 2.
Your LabVIEW installation might not have fully succeeded, or you might not have run the required LabVIEW and Utilities updates. You know where to find the updates, right?
Did you apply the LabVIEW software update Alan refers to?
You do that after using the LabVIEW installation DVD.
Ther’s a link in my signature where you can get it.
You can run the LabVIEW installer and update again and it’s smart enough to add anything you might have missed.
Click and it should give you the locations with the updates. I had the same issue and I had to redo everything so to avoid it, you must click on the URL and download the updates.
