I apologize if this specific question has been asked in the past. I did search for it. I was asked by a member of our code team to pose this question:
Can we use a rasberrypi to host a website offline (LAN) with an old router ? It would all be offline and use only LAN connection.
Thank you.
Team 5234
As long as it does not broadcast any sort of wireless signal and your run everything only over Ethernet ports you should be good.
Thank you for your reply! Helps a lot.
Good luck to you and your team!
Agreed. All of the (off-field) network restrictions are essentially directed at keeping the 802.11 FMS network clear of interference. Wired connections, bluetooth connections, IR connections, have no FRC-legal issues unless they involve drive teams.
