Is this normal for photo vision?
Camera stream freezing, sometimes it never loads, sometimes it can’t connect to the dashboard at all but the detection still worlds fine when we run the code, sometimes when a setting is changed it causes it to freeze or it doesn’t update, like locking it at 5fps even though it is set to 25fps. Refreshing it only fixes it about 50% of the time. I’ve never gotten an OOM error. Updating has made it work more consistently, but these issues still happen occasionally.
Yes, that’s exactly what’s happening to us
Intriguing. Is the delay the same if you are connected to the robot directly over Ethernet as it is when connected over wifi?
Did you find a solution? We’re having the same problem right now.
I ended up restarting computer, reloading the page and it worked. I’m still not quite sure what causes it and it still occurs occasionally
