Hi,
Our code for autonomous is not working properly. We programmed the robot to drive straight for 3 seconds and then stop. Instead of driving forward for 3 seconds and then stopping, the robot waits 10 seconds and drives forward for half a second, then waits another 10 seconds and then drives forward for half a second. We believe that it has to be something wrong with feeding the watchdog since we receive the watchdog not fed error on the dashboard.
4 Questions.
- Could anyone take a look at the code below and tell us what our problem is with the autonomous code?
- Also, if someone could take a look at our line sensor code to see if it will work or not, that would be great
- I’m new to netbeans, how do you save as project (not .java file) on a usb drive or on a different location from where it was originally saved?
- How can I debug the code using System.out.println? It never prints out anything. Are there other ways for debugging the code or knowing what values you get from sensors?
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.AnalogTrigger;
import edu.wpi.first.wpilibj.DigitalInput;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the SimpleRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Team1660Robot extends SimpleRobot {
public Team1660Robot (){
getWatchdog().setExpiration(.5);
* This function is called once each time the robot enters autonomous mode.
AnalogTrigger Bumper = new AnalogTrigger (1);
Joystick rightjoystick = new Joystick(1);
Joystick leftjoystick = new Joystick(2);
RobotDrive robotdrive = new RobotDrive(1,2,3,4);
DigitalInput Mid;
DigitalInput Right;
DigitalInput Left;
Timer timer = new Timer();
double straight = 0;
double standardRobotSpeed = 0.5;
double stop = 0;
double velocity = 3;
public void Team1660Robot(){
Mid = new DigitalInput(2);
Right = new DigitalInput(1);
Left = new DigitalInput(3);
getWatchdog().setEnabled(true);
public void autonomous() {
getWatchdog().feed();
// robotdrive.tankDrive(.5,.5);
//getWatchdog().setEnabled(false);
// getWatchdog().feed();
for(int i =0; i < 10; i=+1){
robotdrive.drive(1,0);
Timer.delay(3);
robotdrive.drive(0,0);
//giveADogABone(3);
// robotdrive.tankDrive(0,0);
//bumper();
// followTheLine();
public void followTheLine() {
Timer Clock = new Timer();
robotdrive.tankDrive(.5, .5);
Timer.delay(10);
robotdrive.drive(0, 0);
Clock.start();
Clock.reset();
//Clock.stop();
if(true)
robotdrive.drive(1, 0);
Timer.delay(5);
//boolean End = true;
for(int i=0;i<10000;++i) {
boolean MidValue = Mid.get() ? true: false;
boolean RightValue = Right.get() ? true: false;
boolean LeftValue = Left.get() ? true : false;
double Velocity;
double direction;
if (MidValue == true && LeftValue == false && RightValue== false) {
Velocity = 5;
direction = 0;
// Go Straight, tape is in center
} else if (MidValue == true && LeftValue == true && RightValue == false){
Velocity = .25;
direction = -0.5;
// Go left if tape is on slight Left//
} else if (MidValue == true && LeftValue == false && RightValue == true){
Velocity = .25;
direction = 0.5;
//Go right if tape is on slight Right//
} else if (MidValue == false && LeftValue == true && RightValue == false){
Velocity = .25;
direction = -0.7;
//Go Left if tape is on extreme Left//
} else if (MidValue == false && RightValue == true && LeftValue == false){
Velocity = .25;
direction = 0.7;
//Go Right if tape is on extreme Right//
} else {
Velocity = .25;
direction = -1;
robotdrive.drive(-Velocity,-direction);
if(Clock.get()>15)
break;
/* if (UseWhite) {
A = RedValue *2 + WhiteValue *4 + BlackValue;
} else if (UseBlack) {
A = RedValue *2 + BlackValue *3 + WhiteValue;
else if (UseRed){
A = RedValue * 2 + BlackValue + WhiteValue;
A=2;
Velocity =2* powerProfile[timeInFull];
turn = 0;
switch (A) {
case 2:
turn = 0;
break;
case 6:if(time > ClockStop) {
End = true;
Velocity = 0.0;
break;
default: if (A != B) {
System.out.println("Time: " + time + " Sensor,Case: " + A + " Velocity: " + Velocity + " turn: " + turn + " End: " + End);
break;
Velocity = robotdrive.getVelocity;
if (A != 0) { A = B;}
//robotdrive.drive(stop,straight);
public void giveADogABone(double timeToWait) {
double WatchdogDelay = 4.9;
while (timeToWait > 0){
if (timeToWait < WatchdogDelay){
Timer.delay (timeToWait);
else {
Timer.delay (WatchdogDelay);
timeToWait = timeToWait - WatchdogDelay;
* This function is called once each time the robot enters operator control.
public void operatorControl() {
while(isEnabled() && isOperatorControl())
robotdrive.tankDrive(leftjoystick, rightjoystick);
if( rightjoystick.getRawButton(8) == true) {
getVelocity();
public double distance_to_time (double distance){
double time = distance / velocity;
return (time);
public void getVelocity (){
robotdrive.drive(standardRobotSpeed,straight);
//5 is the seconds to test
Timer.delay(5);
public void bumper(){
int x = 1;
while (x == 1){
if(Bumper.getTriggerState() == false){
else {
x = 2;
