Issues Deploying to RoboRio
Hello! When we try to deploy our robot code to the RoboRio we get the following pop-up error from VS Code, even though the programming is building successfully.
Failed to attach to remote debuggee VM. Reason: java.net.ConnectException: Connection refused: connect
Have you updated to the latest firmware . It was released on Sunday
We just reimaged the RoboRIO and we are getting the same error unfortunately.
Specifically what steps are you taking to deploy the code?
That message implies you’re trying to run it in debug mode with the vscode remote debugger attached.
