Issues With Shuffleboard Widgets in C++
Shuffleboard widgets duplicating in C++
Issue description:
When trying to update widgets via Shuffleboard in C++, a new widget is added instead of an existing one updating.
What I’d like to happen:
I would like an existing widget’s data to be changed (for example, a boolean box changing from false to true)
What happens:
A new widget with the same title and type as the original is created but the value changes to the desired value.
My code:
1st try, source file:
  if (m_waitingRoomState == redBall) {
    frc::Shuffleboard::GetTab("Drive Core")
      .Add("Room Ball Red", true)
      .WithWidget("Boolean Box")
      .GetEntry();
This produces the previously mentioned result.
2nd try, source file:
    m_roomBallRedBoard.PutBoolean(true);
header file:
  nt::NetworkTableEntry m_roomBallRedBoard = frc::Shuffleboard::GetTab("Drive Core")
    .Add("Room Ball Red", false)
    .WithWidget("Toggle Button")
    .GetEntry();
This was recommended to me but fails to compile due to there not being a PutBoolean method.
If there is any other info that would help, please tell me so I can add it.
Thanks for any help!
The method is SetBoolean, not PutBoolean.
