Posted by Patrick Dingle at 03/08/2001 11:04 PM EST
Coach on team #639, Red B^2, from Ithaca High School and Cornell University.
In Reply to: Re: Sterling Engine
Posted by ChrisH on 03/08/2001 8:13 PM EST:
Again thanks for your thoughtful and detailed reply! Hopefully I can help clarify what I was saying and respond to your points.
: Patrick,
: You raised many debatable points that are obviously products of the pseudoscience popular in the press. I will address them one at a time.
With all respect, my points came from neither the press nor from pseudoscience, but from my own studies carried about with scientific methods, and from other papers that I have read, also carried out by scientists. I assure you I have no intention of believing a word that comes from the press, especially when it comes to science because they are absolutely clueless.
: : Some say the combustable engine was one of the greatest inventions of all time. It was an important an necessary step in the progression of technology, but I will be more than happy to see it go.
: Never heard of a combustable engine. Since most engines work by converting thermal energy into mechanical energy I don’t think it would work very well. I think you were refering to the internal combustion engine. I don’t necessarily think it was the greatest invention nor would I be sad to see it disappear if replaced by something better. You opening sentence merely points out that this is a debatable point. The debatability I agree with.
Of course I meant combustion engine. It was obviously a typo since in all other instances I used the correct spelling, “combustion”.
: : Some of the biproducts in gasoline can give us lung cancer. I feel bad for the people in big cities that breath it in every day. Combustion engines spew CO2 into the atmosphere in huge quantities, far more than forests and the ocean can absorb. This has caused global warming, and will quickly get worse until these engines are eliminated. Gasoline supplies will eventually run out.
: Actually I belive it is unburned or incompletely burned gasoline components that are the problem. Complete combustion releases H2O, CO, CO2 none of which are known carcinogens. If the fuel/air ratio isn’t perfect or the temperature is wrong you’ll get some NO or NOx. These aren’t carcinogens either.
Granted, we may not have proven any link between car fumes and cancer, but come on… It isn’t pleasant to inhale, and it is bad for for your health. You can correct me on technicalities, but this just isn’t a debatable point.
: The case for global warming is certainly not proved. While there does seem to be an increase in temperature readings over a fairly short period (climactically), whether or not this is evidence of a significant climactic change is unknowable at this point as data has not been collected long enough to establish a baseline.
Granted, it’s not proven (nothing in science ever is). However, the evidence is overwhelming. The evidence comes in two flavors. First, there is the statistical evidence that shows that global average temperatures have risen and fallen over the past 200 years with correspondance to the amount of CO2 that released. I did a statistical study of these two sets of data last year (If I can find my report I’ll post the graphs), and statistically the closeness of the two graphs were astonishing. During times that very little CO2 was released (pre-WWI, recession times, etc…), the global temparatures would often start to go down, often a year or so after CO2 emissions started going down. Correspondingly, temperatures would normally start going up shortly after CO2 emissions started increasing. Using mathematical models on the data, I found that, for the amount of CO2 released during any given year, the effect on the global temperature would expenentially decay over time. This means that, for any given year, temperatures would MOST CLOSELY (this is the essence of math modeling) correspond to the sum of each year’s CO2 emission times the exponential decay factor to the appropriate power. I think the decay factor was about 0.7 a year, or a half life of about 1.5 years. More generally, what this means is that if there is an extended period of low CO2 emissions, and then there is a hike, then the temperatures will go up, but the full effect will not be realized for several years after the increase in CO2 emissions. Likewise, when CO2 emissions decrease, the temperatures will go down, but at some delay. From my study (not any propaganda from pseudoscientific left extremest media freaks), I found that the statistical evidence was absolutely overwhelming.
The interesting thing about my study, is that when I started, I was extremely skeptical that global warming was caused by humans. When I actually did my research project, looked and examined the data, there was just no way I could make the case that it isn’t caused by (at least in a major part) by humans.
Now the second set of evidence that shows human CO2 emissions cause global warming is the “scientific” (not mathematical and statistical) evidence. I have not studied this part in depth, but from the papers I have read, it has been proven that CO2 causes global warming. It also has been proven that burning of fossil fuels gives off CO2. It also has been proven that humans burn fossil fuels. Therefore, it has been proven that humans cause global warming. However, I think the more relevent question here is:
To what extent do humans cause global warming?
This is the point where your argument has the most leverage, for this question is extremely difficult to scientifically quantatize a vector field of CO2 movement for an entire planet. This is why I took a statistical look at raw data.
: Finally there is no way to pin so-called global warming on CO2 emmisions other than a computer model that seems to indicate this. There may be other factors involved, slight changes in Earth’s orbit or a fluctuation in solar energy output for example. Or a different chemical species (freon anyone?) Or merely putting all the temperature measuring stations on the top of a tall building with an asphalt roof, instead of the middle of a field where they used to be. I would be surprised to find even a single location where you could find temperature measurements had been taken for a century in the exact same location with the same instrument or instruments that could be calibrated to a common standard.
I’ve read all these arguments before. Its funny, these are the same arguments I see over and over. These arguments seem very pseudo-scientific, since they are just speculation, and have no real data to show that different temperature-reading methods result in different temperature readings – especially an upward trend over time. It is certainly true that the methods and locations we use to record temperatures over time have changed. I also adressed this in my paper (which I REALLY wish I could find and send to you). However, the statistics even destroy this argument, for within smaller periods of times when the same methods / locations for recording temperatures, temperature still corresponded (not as overwhelmingly, but still statistically significant) to CO2 emissions. This includes both rises AND falls in CO2 emissions.
: : What really irritates me is how politicians don’t care about this problem (they all say they do, but they’re all hypocrites). With the high gasoline prices, they did not talk about exploring alternatives
to gasoline, but opening up parts of Alaska for drilling.
: Politics will never be the answer to technical issues. Politics is a product of government. Government’s
: purpose is to help us all get along together and resolve people issues, not technical ones. Don’t blame them for not solving a problem (if it is one) they didn’t create nor are they equiped to solve.
I agree with you there. Well said.
: : THANK YOU Dean Kamen and DEKA for addressing this important problem. If a car comes out that runs on a modification of the Sterling Engine, I will be among the first to buy it. Hopefully costs will be low enough that combustion engines will forever disappear. Next, let’s get rid of all the power plants that use combustion as a means to produce power. Unfortanutely this invention will cause a HUGE shift in the world economy, and many countries will lose their one and only primary export – gasoline. However, the benefits far outweigh the drawbacks.
: So you would maybe prefer Nuclear plants? Even Sterling engines need a temperature differential to run. If you light a wood fire to heat your coffee to run your sterling engine you’re using combustion and if you used it to generate electricity the efficiency
: would be very low. Far lower than a modern coal fired
: power plant. Since you posted this on a computer network I don’t suppose you object to having electricity, just how it’s made.
There is no problem with generating heat (using electricity). That is not a problem, because of the law of conservation of energy. We will never increase temperatures on the planet by using electricity, because there is always an equal and opposite reaction that requires the heat for the chemical reaction to occur. What is the problem is trapping more and more energy from other celestial bodies (e.g. the sun).
: : Dean Kamen is eliminating all the negative sides of technology.
: I don’t think even he would claim that. Besides you never solve a problem, you merely change the old problems for a new set. The only question is whether the new or old set is easier to live with. I’m sure that any revolutionary invention will create a new set of problems that at the outset are quite unanticipated. For example automobiles were often praised in the early days for eliminating the fly problems in large cities. (where you have horses there will be flies) Which problem would you rather deal with flies or smog?
: This is too long already but things are rarely as simple as they seem. Nothing personal Patrick, the media rarely publishes the criticisms of theories they think are “right” (as in they fit with thier agenda, no relation to factuality). Consequently you are probably unaware of the controversy around some of these issues.
I hope you reconsider your above comments based on my reply. I understand your concern and skepticism of on what basis the media comes up with their conclusions. However, please don’t steriotype others as being malinformed simply because they happen to take a stance that corresponds to the stances often taken by the media.
But, all these technical issues and detials aside (granted, they are important), the point of my last message was just to show my full support in favor of replacing gasoline-powered automobiles with something much cleaner and more reliable… and I think Dean’s DEKA is on the horizon of doing just that.
Patrick
