jaguar scaling factors
I would suggest using PID with encoders to get a closed-loop control.
There’s nothing quite like feedback for repeatability and low-speed handling.
Can you suggest any good resources for creating PID algorithms? I am used to text based languages on OS/2 so any resources that are labview based would be nice.
If you’re using LabVIEW, the FRC version does include a PID toolkit. Note that the LabVIEW toolkit uses the Standard form rather than the Ideal form.
Wikipedia has a good article on PID.
I read through the article posted and I am trying to make heads or tails of it. I do not understand how exactly a PID loop will allow me to synchronize the movements of the left and rights drivetrains so that the robot drives in a straight line. PID does however seem to be an excellent way of defining the movements during autonomous to place the ubertube.
More questions:
  1. How do I use PID to make the system drive in a straight controllable line while not sacrificing response times?
  2. Is PID a good choice for autonomous?
  3. Is all of this overkill for what I am trying to achieve?
  1. If you use the joystick controls to set a velocity that you use a PID loop to maintain instead of setting the Jaguar values directly the robot should maintain equal velocity on both sides and drive in a straight line.
  2. Yes, PID control on position is a good way to handle dead reckoning forward/back movements in autonomous. PID control on angle using a gyro is a good way to make dead reckoning turns.
  3. Nope, not at all.
so do I use one PID VI for each input needed on the drive VI?
In my question about autonomous, would I want to use a setpoint VI.
Lastly, does the PID VI need to be in a loop to work? Sorry for all the questions, but short and simple answers for APPLYING code are few and far between over at NI’s site.
Have you tried calibrating the speed controllers?
I have, but there is still a slight variance from straight on.
Yes, yes, and yes.
I think a global variable would work wonderfully for transferring your setpoint from your autonomous code to your PID loops. Put the PID loops in Periodic Tasks so that they run all the time.
Should the PID Loop run with a delay or should it run at full speed?
Well, the PID probably isn’t your most critical task, so a delay would be good. I would give it a delay of 5 to 25ms.
One thing I may have neglected to tell you:
PID doesn’t “just work”. You have to tune it.
Luckily, temporary deployments in LabVIEW make that easy. Just create a control for the parameters, and tune until it works. Make sure to start with Proportional, and then tune the others to whatever is appropriate.
EDIT:
Feel free to post your code. An easy way to post your whole project is to zip the folder it is contained in, and just upload the zip as a whole. To make it smaller, you can delete the “Builds” folder first.
I don’t want to move this thread in a different direction, but could you please elaborate on how you measured the output voltage?
Did you use a volt meter, scope, other?
Were motors connected to the outputs?
Did you take these measurements at the same time (measure one, then the other, same setup)?
-David
I assumed the duty cycle at full on was 100% so I simply used a voltmeter
Set to DC. No motors. No load.
Measured two Black and two Grey
Full forward and full reverse
Same result consistently.
This is a false measurment. The Gray Jags at full really drop maybe .15v more than the Black Jag.
Your measurement was just a by-product of the Gray Jaguar circuit design.
It doesn’t measure properly without a load.
The Black Jaguar has a different design that doesn’t affect no-load measurements.
I tripped over that myself earlier, although you have to read several surrounding posts to understand what was going on in that thread.
I liked Eric’s way of putting it…
What about creating a slider “trim” control.
Your “trim” control would run joystick position through a multiplier on one set of Jags. Experiment with trim position until you’re satisfied that you’re driving in a straight line.
This method will only be suitable if the differences between the Jags are consistent at various speeds.
Thanks Mark.
We do clearly have a small speed difference between black and grey as well. Much harder to measure though.
I’ll measure under load and see what I get.
I don’t think the offset is linear. I just tried my code today with the speed being divided by two and the robot drives much straighter. I haven’t had a chance to test PID yet. Electronics guys are still trying to get encoders connected.
I should have mentioned this much earlier. How much wire do you have feeding the two sides of the robot? A frequent problem is inches feeding one side of the robot with feet feeding the other side. If you are using #12 to feed the drive system, you can accumulate significant loss in the wiring. It amounts to about 0.2 volts per foot at near stall current for CIM motors. Remember you have to count both the black and red wires to arrive at the correct calculation. It is for this reason that I recommend a central location for the PD to balance the wiring.
all wiring runs follow the same path, we had the problem you are describing last year
