I am just driving to write a simple program to get the motors to drive using a joystick. I can deploy it and it throws no errors but when I move the joystick nothing happens. Any help would be greatly appreciated!
Robot code posted below:
Class Robot:
package org.usfirst.frc.team5407.robot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
The VM is configured to automatically run this class, and to call the
functions corresponding to each mode, as described in the IterativeRobot
documentation. If you change the name of this class or the package after
creating this project, you must also update the manifest file in the resource
directory.
public class Robot extends IterativeRobot {//Declare classes up here RobotBase robotbase = new RobotBase(0,1); Inputs inputs = new Inputs(0);
// final String defaultAuto = “Default”;
// final String customAuto = “My Auto”;
// String autoSelected;
// SendableChooser chooser;
public void robotInit() {
//Class inputs go here
// robotbase = new RobotBase(0,1);
// inputs = new Inputs(0);
// sensors = new Sensors();
// solenoids = new Solenoids( //Drive train gear shifter w
// chooser = new SendableChooser();
// chooser.addDefault(“Default Auto”, defaultAuto);
// chooser.addObject(“My Auto”, customAuto);
// SmartDashboard.putData(“Auto choices”, chooser);
// autoSelected = (String) chooser.getSelected();
// autoSelected = SmartDashboard.getString(“Auto Selector”, defaultAuto);
// System.out.println("Auto selected: " + autoSelected);
* This function is called periodically during autonomous
//switch(autoSelected) {
//case customAuto:
//Put custom auto code here
// break;
//case defaultAuto:
//default:
//Put default auto code here
//break;
* This function is called periodically during operator control
//double counter = 0.0; //Counter writes value to SmartDashboard to verify connection
while (isOperatorControl() && isEnabled()){
//SmartDashboard.putNumber("Counter", counter++);
//Timer.delay(0.10);
//Put class.update here for robot think
inputs.readValues();
robotbase.update();
robotThink();
public void robotThink(){
robotbase.d_LeftDriveMotor = inputs.d_PowerArcadeDrive - inputs.d_TurnArcadeDrive;
robotbase.d_RightDriveMotor = inputs.d_PowerArcadeDrive + inputs.d_TurnArcadeDrive;
* This function is called periodically during test mode
public void testPeriodic() {
LiveWindow.run(); //Allows values to update
Class RobotBase:
import edu.wpi.first.wpilibj.Spark;
public class RobotBase {
//SpeedControllers go here ex: Mot_DriveMotor
Spark mot_LeftDriveMotor;
Spark mot_RightDriveMotor;
//Doubles go here ex: d_DriveMotor
double d_LeftDriveMotor;
double d_RightDriveMotor;
public RobotBase(int PWMConnector_LeftDriveMotor, int PWMConnector_RightDriveMotor){
mot_LeftDriveMotor = new Spark(PWMConnector_LeftDriveMotor);
mot_RightDriveMotor = new Spark(PWMConnector_RightDriveMotor);
//Make sure all motors are stopped
mot_LeftDriveMotor.set(0.0);
mot_RightDriveMotor.set(0.0);
public void update(){
Class Inputs:
public class Inputs {
Joystick joy_DriveStick;
//doubles go under here
double d_PowerArcadeDrive;
double d_TurnArcadeDrive;
//booleans go under here
//boolean b_DualSpeedShifter;
public Inputs(int USBConnector_Drivestick){
joy_DriveStick = new Joystick(USBConnector_Drivestick);
zeroInputs();
public void readValues(){
//Joystick X,Y,Z, Pov and Throttle go under here
d_PowerArcadeDrive = joy_DriveStick.getX() * -1;
d_TurnArcadeDrive = joy_DriveStick.getY() * -1;
// if (Math.abs(d_PowerArcadeDrive)<.01) {
// d_PowerArcadeDrive = 0;
// if (Math.abs(d_TurnArcadeDrive)<.01){
// d_TurnArcadeDrive = 0;
//and an if that if the value is smaller disregard it if its bigger then use it
public void zeroInputs(){
this.d_TurnArcadeDrive = 0.0;
this.d_PowerArcadeDrive = 0.0;
