Java earors
I am having to set up a program for a first robotics event and I was told to use java. So I installed java and ran some code on vs code but it was saying that I had no path in addition to “Java 11 required”. How do I find the jdk11 path and add it to my computers path. I have trued using the control panel and it rejected every command. This is about all the information I can think of thank you
A manual install will likely not work as intended.
Start here: https://docs.wpilib.org/en/latest/docs/getting-started/getting-started-frc-control-system/index.html
