Here is the code … trying to get the result makes the roboRio show that it has no code in the driver station and the error seems to be the code.
Commenting out the lines
var result = camera.getLatestResult();
pHasTarget = result.hasTargets();
lets the robot come alive again, but leaves us without the vision data
// Copyright (c) FIRST and other WPILib contributors.
// Open Source Software; you can modify and/or share it under the terms of
// the WPILib BSD license file in the root directory of this project.
package frc.robot;
import edu.wpi.first.wpilibj.CounterBase;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.motorcontrol.Victor;
import edu.wpi.first.wpilibj.motorcontrol.Spark;
import edu.wpi.first.wpilibj.SPI; // required for ADIS IMUs
//import edu.wpi.first.wpilibj.ADIS16448_IMU;
import edu.wpi.first.wpilibj.ADIS16470_IMU;
import org.photonvision.PhotonCamera; //https://maven.photonvision.org/repository/internal/org/photonvision/PhotonLib-json/1.0/PhotonLib-json-1.0.json
private final Spark m_rightDrive = new Spark(0);
private final Spark m_leftDrive = new Spark(1);
private final Victor shooter = new Victor(3);
private final DifferentialDrive m_robotDrive = new DifferentialDrive(m_leftDrive, m_rightDrive);
private final XboxController m_stick = new XboxController(0);
private final Timer m_timer = new Timer();
private final Encoder right_encoder = new Encoder(6, 7, true, CounterBase.EncodingType.k4X);
private final Encoder left_encoder = new Encoder(8, 9, false, CounterBase.EncodingType.k4X);
//public static final ADIS16448_IMU imu = new ADIS16448_IMU(ADIS16448_IMU.IMUAxis.kY, SPI.Port.kMXP, ADIS16448_IMU.CalibrationTime._1s);
public static final ADIS16470_IMU imu = new ADIS16470_IMU(ADIS16470_IMU.IMUAxis.kY,ADIS16470_IMU.IMUAxis.kX,ADIS16470_IMU.IMUAxis.kZ, SPI.Port.kOnboardCS0, ADIS16470_IMU.CalibrationTime._1s);
PhotonCamera camera = new PhotonCamera(“Camera_Module_v1”); //wide angle on rPi3 is called “OV5647”
//other camera on rPi4 is called “Camera_Module_v3”
public double SpeedForward,rotationClockwise,cYaw;
public static double pTargetYaw;
public static boolean pHasTarget;
public static double Sharpness = 0.3;
public static double MaxTurnEffort = 0.25;
public static double shooterSpeed = 0.3;
@Override
public void robotInit() {
imu.calibrate();
m_rightDrive.setInverted(true);
right_encoder.setSamplesToAverage(5);
left_encoder.setSamplesToAverage(5);
right_encoder.setDistancePerPulse(6.0 * 0.3048 /8093); // the pulses where averaged from l&r = 8093 of 6' (3 x 2' tiles)
left_encoder.setDistancePerPulse( 6.0 * 0.3048 /8093); // the factor 0.3048 converts feet into metres
right_encoder.setMinRate(1.0);
left_encoder.setMinRate(1.0);
right_encoder.reset();
left_encoder.reset();
SmartDashboard.putNumber("Sharpness", Sharpness);
SmartDashboard.putNumber("MaxTurnEffort", MaxTurnEffort);
SmartDashboard.putNumber("Shooter Speed", shooterSpeed);
@Override
public void robotPeriodic(){
if (pHasTarget) {
pTargetYaw = result.getBestTarget().getYaw();
SmartDashboard.putBoolean("Has Target",pHasTarget);
SmartDashboard.putNumber("TargetID", result.getBestTarget().getFiducialId());
SmartDashboard.putNumber("Target Yaw", pTargetYaw);
cYaw = -imu.getAngle(ADIS16470_IMU.IMUAxis.kY) % 360;
SmartDashboard.putNumber("Angle", -imu.getAngle(ADIS16470_IMU.IMUAxis.kY));
SmartDashboard.putNumber("cYaw", cYaw);
SmartDashboard.putNumber("R_Encoder Distance", right_encoder.getDistance());
SmartDashboard.putNumber("L_Encoder Distance", left_encoder.getDistance());
SmartDashboard.putNumber("R_Encoder", right_encoder.get());
SmartDashboard.putNumber("L_Encoder", left_encoder.get());
SmartDashboard.putNumber("Rotation Clockwise", rotationClockwise);
//Sharpness = SmartDashboard.getNumber("Sharpness",Sharpness);
//MaxTurnEffort = SmartDashboard.getNumber("MaxTurnEffort", MaxTurnEffort);
//shooterSpeed = SmartDashboard.getNumber("Shooter Speed",shooterSpeed);
@Override
// m_timer.reset();
// m_timer.start();
/** This function is called periodically during autonomous. */
@Override
// if (right_encoder.getDistance() < (1.00)) { //only drive when the encoder reads less than 1.00 m – NEEDS ENCODERS TO PREVENT WILD ROBOT –
if (m_timer.get() < 2) { //only drive when the timer is less than 2 seconds
m_robotDrive.arcadeDrive(0.5, 0.0,false); // drive forwards half speed
} else {
m_robotDrive.stopMotor(); // stop robot
@Override
shooter.set(shooterSpeed);
if (m_stick.getLeftBumper()) {
if (m_stick.getRightBumper()) {
imu.reset();
SpeedForward = m_stick.getRightTriggerAxis()-m_stick.getLeftTriggerAxis();
rotationClockwise = m_stick.getLeftX()*0.6;
rotationClockwise = m_stick.getYButton() ?(1-Math.exp(-Sharpness*Math.pow(cYaw,2)))*Math.signum(cYaw)MaxTurnEffort: rotationClockwise;
// rotationClockwise = m_stick.getXButton() ?(1-Math.exp(-SharpnessMath.pow(pTargetYaw,2)))*Math.signum(pTargetYaw)*MaxTurnEffort: rotationClockwise;
m_robotDrive.arcadeDrive(SpeedForward, rotationClockwise,false);
