Hey folks! Amidst work on this year’s vision code, I’m running into a problem. After 2+ hours of searching, I’m stumped.
We have this code running:
Mat source = new Mat();
Mat processingImg = new Mat();
while (!Thread.interrupted()) {
// Get frame from camera
cvSink.grabFrame(source);
if (source.empty()) {
System.out.println("Cannot get camera frame");
continue;
// Convert BGR to HSV (easier to process hue than rgb)
Imgproc.cvtColor(source, processingImg, Imgproc.COLOR_BGR2HSV);
// Turn green (within range) white, all else black
Core.inRange(
processingImg,
new Scalar(50, 50, 40),
new Scalar(90, 150, 245),
processingImg
// Blur black + white image (remove outlier pixels)
Imgproc.blur(processingImg, processingImg, new Size(10, 10));
// Find countours (white objects) in image
ArrayList<MatOfPoint> contours = new ArrayList<MatOfPoint>();
///////////////// THE CULPRIT LINE: /////////////////
Imgproc.findContours(processingImg, contours, new Mat(), Imgproc.RETR_EXTERNAL, Imgproc.CHAIN_APPROX_SIMPLE);
// Send vision feed to dashboard
outputStream.putFrame(source);
The code works for about 60 seconds before the following error appears:
OpenCV(3.4.4) Error: Insufficient memory (Failed to allocate 921600 bytes) in OutOfMemoryError, file /var/lib/jenkins/workspace/OpenCV/OpenCV - Release/arm/opencv/modules/core/src/alloc.cpp, line 55
Exception in thread "Thread-0" CvException [org.opencv.core.CvException: cv::Exception: OpenCV(3.4.4) /var/lib/jenkins/workspace/OpenCV/OpenCV - Release/arm/opencv/modules/core/src/alloc.cpp:55: error: (-4:Insufficient memory) Failed to allocate 921600 bytes in function 'OutOfMemoryError'
at org.opencv.imgproc.Imgproc.cvtColor_1(Native Method)
at org.opencv.imgproc.Imgproc.cvtColor(Imgproc.java:2223)
at frc.robot.subsystems.Camera.run(Camera.java:74)
at java.base/java.lang.Thread.run(Unknown Source)
After the error, the majority of the system continues to operate, but the camera thread freezes completely.
The error takes places on the cvtColor
line, but that doesn’t actually seem to be the issue. Instead, removing the Imgproc.findContours()
line solves the problem (the robot never runs out of memory), but finding the contours is crucial to the vision code’s success.
Any ideas?
