With FIRST and Sun announcing Java support in the cRio, I’ve added a Java sub-forum in the Programming area of the forums. Update your portal listings if you’re interested in having posts from this forum show up on your portal listing.
Did you know you could do that? Click ‘config’ in the upper right corner of the portal and you can narrow down the portal thread listing to just those sub-forums you’re interested in.
