JB weld question...
A while back… I suggested using the wonderful J.B. weld as a perminant solution, and The team thought that it wasn’t the best Idea, because we thought that it was more of a “fix it” product than a production product.I was just wondering weather or not anybody on this forum has any experience with the stuff and if your results were good. I have used it before… and it held allright, plus the user reviews all seem to be astounding… But if you’ve had any bad experiences with it, please post them here :slight_smile:
Thanx in advance
-CodyC
epoxy is stronger than the resin used in fiberglass construction (boat hulls, car bodies…)
it is definately a production quality material, and JB weld is one of the best epoxy products on the market.
the storys about it are true. I fixed a leak in the oil pan (small hole on the side) on my Fiero, and it lasted 3 years at least (I sold the car)
Funny, I used JB Weld for the same purpose, reinforcing the hole with a screw. Held up great.
JB Weld is a fairly good adhesive and an excellent filler. It has a lot of compressive strength, moderate shear, and poor tensile strength. It adheres well under poor conditions (heat, oil, chemicals) but isn’t as good underwater. I knew a fellow who repaired a crackled engine block with it, that’s where I first heard of it (over 20 years ago!!)
There are far stronger adhesives, like the clear stuff in a doiuble-tube syringe from Radio Shack (and others), but these are poor fillers. I recommend buying a small package and playing with it, you;'ll learn what it can and cannot do.
Hope that helps.
Don
I’ve seen a FIRST robot with its drive gearboxes held together by a similar product (it was titanium-filled, instead of steel-filled like J.B. Weld). It worked…but wasn’t pretty.* I’d advise against that particular application.
When using it, watch out for the fact that it slumps as it dries, so it can be tricky to apply precisely to oddly-shaped surfaces. (I’ve also used a Devcon-brand aluminum-filled epoxy that is of a thicker consistency, which is more easily applied to complex shapes.) Also, though it’s stronger than fibreglass resin, if you’re using significant quantities of it as a structural reinforcement, it should itself be reinforced with something like a fibreglass mesh.
*The team was 919, Harbord C.I., in 2002.
What Tristan said - I recently was suprized to learn that while epoxy is curing at first it gets more runny, then it gets thicker as it hardens.
