joystick axis in labview
Hello, I want to know how is the axis in joystick, because i want programing one motor that jostick when I move up, the motor moves forward,I move down, the motor moves back
And, how is the axis in jostick?
Thank you:confused:
You want to use the Joystick Get or Get Axis. I think Axis 2 is the Y. It returns -1 to 1 range, -1 forward and 1 backwards.
Outside the loop do a joystick open and close on the left and right.
Greg McKaskle
I want programing in Labview… what icon work? why in labview I see 6 axis? i dont understand
Thank you
choose axis 3…
The other axis, are nothing to worry about…
Actually axis 1 (x) is right/left, axis 2 (y) is up/down and axis 3 is the throttle on the bottom front of the joystick. The other axis don’t exist on this joystick but other joysticks can have them.
isnt that what i just said :stuck_out_tongue:
I can move one motor with up/down, in the program is open motor jaguar-with josystick get and axis Y - motor set speed
Is the correct program for move one motor with only Axis Y
Thank you!!!
Basic Robot Main.vi (83.9 KB)
Not quite.
