Joystick Axis missing (Rookie Team 5726)
Hello, I am Gavin Levis from team 5726. We recently ran into an error when trying to move our robot.
After uploading the robot code from eclipse to the roboRIO and getting all green in the driver station, we tried moving the joystick. However, the robot did not move and in the logs of the driver station it said “Joystick Axis missing”.
Pull up the USB tab on driverstation and test if moving / pressing everything on your joystick shows up there. If not, check your joystick, cable, USB port, etc. If it does, check the joystick numbers in your robot program.
