Joystick disconnecting constantly during match
Hi,
We (4557) are currently competing at the NE DCMP. So far it has been going well, but we have encountered a problem that can be… problematic at times.
One of our joysticks (specifically a HOTAS of this model) often disconnects during a match (i.e. the driver station stops seeing it). This is quickly remedied by a rescan of the joysticks. Nevertheless, it slows us down somewhat and even prevented us from getting on the batter at one point at the end of a match.
An FTA at our event suggested two options: static building up (in which case, we should ground ourselves and the joystick to a metal beam in the castle before a match) or the USB power saving mode getting in the way (we turned that off). We haven’t actually been able to test if either of these solutions work (that was after our last match today), but I was wondering if there are any other possible reasons for this happening. Are there known problems with this like with the Xbox 1 controller?
Thanks for the help.
Some people have reported that the Xbox One controller does do weird things with the Driver Station app and has sometimes been found to have issues playing nicely with other controllers. Of course, theirs might have been some other issue, too. (e.g., http://www.chiefdelphi.com/forums/showthread.php?t=142183)
Our team has run into similar problems with our joystick connectivity. The problem for us turned out to be the usb port so for a temporary fix we used a USB hub on the good port and it helped. But we use different joysticks so it may be a different issue.
This!
Yea, it’s worth switching USB ports to see if the problem follows the controller or stays with a particular USB port.
If you cant get a hub, grab a separate (like a classmate from the FTA’s or a friendly team can lend you one) and see if it happens there. If it doesnt, then you know it is a issue with your USB ports. The reasoning for getting a different computer is because it could be a issue with the motherboard in general, and more than just those ports could be effected.
Does the problem occur both on battery and on wall power?
The op left out something I was told about this situation ( I am a mentor on 4557) it seemed to happen when another robot hit our driver station wall. Now I heard this second hand, but may add another twist to the issue.
Also I was told that the drive computer wasn’t plugged into ac outlet in station.
Would a bad joystick driver cause it to disconnect like that?
There might be a driver you could download from the Internet specifically for your joystick.
To the best of my knowledge this just started happening today. Same joysticks were used at two district events. Now I was not there today to witness the events happen, but am personally leaning towards USB ports in computer or a sketchy connection on the motherboard.
The part that throws me off is yet another twist it supposedly only happened on competition field, not on practice field or practice areas.
The practice field working has me very perplexed. How many matches has this occurred in?
We were having issues with our Xbox controller randomly shutting off and updating the drivers fixed it.
My thoughts are that it could be a bad USB Port (which others have talked about), or it could be a bad Joystick.
Try it with a different joystick in a different USB port.
“bad joystick” includes:
  1. Worn connector
  2. internally frayed wires, which you can’t see
Sudden bumps causing the problem lends me to believe the problem is in the physical connection between the joystick and the computer. Either the port is bad, or the connector on the joystick. Or, some combination of both.
Did you ever try running under the same no PC power conditions in the pit and at the practice field, too, before you started making power changes? It’s always good to repeat all original conditions to try getting it to occur off the field.
A team I worked with stopped driving on one side while at competition.
We isolated it to their game controller.
But the same problem happened with their backup game controller, though.
It turned out to be both game controllers. A borrowed one from another team worked.
That particular Thrustmaster joystick also has presets and mapping buttons that might be half triggering from being jostled by robots hitting the player station wall.
Also, for power saving did you disable every type?
  • Power Options / Put the computer to sleep (Never or some longer time)
  • USB power saving: Device Manager / Universal Serial Bus Controllers / USB Root Hub & Generic USB Hub properties (each one of them) / Power Management / unclick “Allow the computer to turn off this device to save power”
    -USB selective suspend: Power Options / Change Plan Settings / Change Advanced Power Settings / USB Settings / USB Selective Suspend Setting / disable both On battery & Plugged In
After you’ve applied Mark’s changes, please post the output of running this command at the command prompt. Best if you put the output in the file and upload it as an attachment.
powercfg /query
Our team has had several issues with connectivity of our xbox controllers to the DS. We have one Xbox One controller and one Xbox 360 controller. The DS would stop responding until we unplugged the XB1 controller. Sometimes, the controllers would get swapped in DS (Xbox One controller would show up as 360 and vice versa). The problem still occurred when we tried using USB hubs and switching to other computers. We only could test on other Windows 10 machines, however. This problem was somewhat rare (didn’t occur during our matches), but still a nuisance.
I’d suggest listing specs of your driverstation laptop. I’ve had driver issues with Windows 10 on my personal computer, too, especially with USB 3 ports.
It seems that plugging the laptop in on the driver station helped, though it didn’t totally alleviate the problem. Instead of disconnecting 4-5 times a match, it seemed to happen only once.
It is less of an inconvenience now, but something I would really like to solve for whenever we compete next.
When you are actively using the computer, nothing you are using should go into sleep mode.
Might be a bad USB Controller. When plugged in, it might get a little more power to overcome a defect in the controller.
Ditto for a marginal USB connection. Extra power can overcome a marginal connection.
Do you run with the problematic controller plugged alone into a direct USB port? Or has it been sharing a USB hub with other devices?
I have seen power hungry controllers (lots of lights, bells & whistles) that didn’t like to share the limited USB power provided through a hub and would be the only device to drop out (brown out) if the overall power supplied through the USB port couldn’t support all the devices hanging off that one computer port.
