Joystick getAxis in wpilibj
WPIlibj currently has:
public double getAxis(final AxisType axis) {
switch (axis.value) {
case AxisType.kX_val:
return getX();
case AxisType.kY_val:
return getY();
case AxisType.kZ_val:
return getZ();
case AxisType.kTwist_val:
return getTwist();
case AxisType.kThrottle_val:
return getThrottle();
default:
return 0.0;
I think there should also be:
case AxisType.kNumAxis_val
before the default. Does anyone know where wpilibj issues can be reported?
If you mean like
joystick.getRawAxis(#)   //#= AxisNumber
wpilib bugs can be reported in the wpilib tracker: http://firstforge.wpi.edu/sf/tracker/do/listArtifacts/projects.wpilib/tracker.wpilib_java_bugs
In case that link ever changes, I will also mention it is included in the Eclipse Plug-in help, if that is the IDE and FRC Plug-in set you are using. It can be found by following the “report bugs” link on the troubleshooting page of the help contents for both the core and program builder plug-ins.
