Necisito help with the joystick movement. My team wants to figure out how to get the joystick movement values to output in LabVIEW. Nothing we have found has helped us. :ahh:
In the Basic Framework the have outputs in the code already. I assume you mean you want to get the data from the Joystick axis in which case you could use the Get Axis VI. (WPI Robotics Library > DriverStation > Joystick > GetAxis.VI)
http://img242.imageshack.us/img242/87/getaxis1oi3.jpg
If you mean you want to see the values in real-time on the front panel, then you could just right click on the output node and select Create > Indicator.
http://img160.imageshack.us/img160/7450/getaxis2gx6.jpg
I hope that helps!
- Austin
