Joystick Problem
Hello Im a Programer for team 2647. Im having trouble with the joystick. I have followed the manual where we have to upload the example program into the crio. The first time the joystick had comunication with the jaguars and motors. The second I uploaded the new image, The joystick stop communicating. Is there any solution to this problem?
when you re-image the cRio, you delete all existing code on it.
go to labview (assuming thats what you are using) and redeploy the code… it should work then.
just deploy the code from whatever software you are using and it should work
Thank you for your help. IT WORKS :slight_smile:
