Kit Pick-up
Posted by Michael Martus.   [PICTURE: SAME | NEW | HELP]
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
Posted on 10/11/2000 7:03 PM MST
Monday is the day! October 16th. for kit pick up.
Place: Pontiac Central High School
Time: 12:00 noon to 6:00pm
Pontiac Central is located on Huron Street (M59), just west of Wide Track and east of Telegraph Rd. in Pontiac.
There is a light in front of the school - do not turn there. Go to the street that is west of the light called Prall Street turn there. Then go to stop sign. This is the loading dock/autoshop entrance ramp. You will see the dumpsters at the edge of the drive. Turn right into the drive.
Autoshop entrance is on the right, it will be marked and open.
I can be paged at 810-402-0317 if you need assistance.
You will be getting the following:
2 - Grey plastic crates, 54 lbs each.
1 - Robot control box - assembled
1 - Operator control center - assembled
You will sign for the kit. Inventory sheets will be given for you to check items at a later date. If parts are missing (they were carefully checked several times) they will be made available as needed.
