I need help we are trying to run our kraken x60 and can control it from phoenix tuner but when we use the following code it won’t run at all. We are using
VoltageOut
with setControl
to try and set a voltage of 10 volts which when we test VoltageOut
in Tuner X we see the motor behaving as expected and moving. We disabled FOC
and the limit switches in the motor config thinking maybe that was the issue, but that hasn’t helped either.
I’m sure its something really dumb but we have looked at other team’s code and the example code for multiple meetings and I’m not sure what else to do at this point.
