LabVeiw Code Deployment
Ok so I am trying to put code on to the cRIO and use the classmate as the driverstation.
In labView in the project manager I go to build dependecies and right click and click on “run as startup” and then it tells me that it completed the process and then I need to reboot the cRIO and I allow the computer to do it. I then plug in the classmate and it gets communication with the cRIO, but it tells me that no code is detected. Did I do some thing wrong?
First thing i would do is to open up labView and open your project. Go to the “File” menu and hit the button that says debug. A popup should appear asking if you want to debug your code. Click yes and a status bar will appear on the screen. After it completes, retry the connection.
Before you chose “Run as Startup”, did you first “Build” the project?
we’re having the same problem… the exact same thing as you except ours is showing code but when we start teleop or autonomous… nothing happens! it’ll run but our joysticks and buttons do nada
Build project
Run as startup
Reboot does not seem to work that well from labview
Reboot from the driver station under diagnostics tab (I think)
Wait for a few until you get communication and Robot Code
Hope this helps
also, make sure you read the dialog box during deployment. If, when it’s finished and waits for you to click a button (i forget which), it says “deployment completed with errors” then it didn’t work. Simplest troubleshooting for this would be cold reseting the cRIo and trying again.
