labview download?
(Rookies)
On the 2go pc, is there a place i can download labview to get it on, or do i have to use an external disc drive?
This year, the NI Software came on a USB flash drive. You should just be able to plug it into the laptop and install from there.
Did your kit come with a CD?
Our Kit this year came with a USB, you should be able to use that. (A very nifty USB that swivels and stuff :P)
Open the package, it may fool you. It isnt a CD inside it. ALSO, KEEP the package, it has the serial number you need to verify it.
i already installed the USB…is there 2? Or where can i find the program at? I attempted to search for it.
Start Menu -> National Instruments -> LabVIEW 2011 -> LabVIEW
Also, you need this update installed:
http://joule.ni.com/nidu/cds/view/p/id/2263
Password for unpackaging is:
!HotShots!KnowBalance!
I installed 1 usb. is there 2 usbs that came with the kit?
Nope, just 1. That’s all you need.
panic has ended. i found it. thanks for help.
No problem, don’t forget the updates. You cant create a FRC Project without it!
