Labview Error 7
Whenever we try to deploy code the following pops up:
Error 7 occuree at CAll Library Function Node in NetComm_CAN_Send.vi:20-
>WPI_CANJaguar_GetTransaction.vi:1-
>WPI_CANJAguar_GetVersion.vi-
>WPI_MotorControlOpenCANJaguar.vi
>Begin.vi
Possible Reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example use \ as path seperators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
All of the code seems to be in the proper directories. We have not deleted any files. We know it isnt an update since it worked for a week after them.
Does anyone know how to fix this error? Any help would be greatly appreciated.
When you imaged your cRIO, which CAN support plugin did you choose?
We do not know. How does one aquire such information?
Ask the person who imaged your cRIO what they chose.
You select the plugin from the available options in the FRC 2012 cRIO Imaging Tool. The list is labeled “CAN Driver Plugin” and is in the middle of the left side of the window.
Select the option that matches the hardware you’re using as a CAN gateway, and Apply the changes.
