LABVIEW HELP Falcon 500 RPM
I’m trying to get the RPM from the falcon 500 for our shooting mechanism but whenever i do get velocity I’m getting 17000. I see that it says raw sensor units so do I need to do some math/converting it to RPM?
Those are the encoder ticks. I haven’t worked with the falcons but I would assume that is ticks per second. There are 2048 ticks per rotation so your motor is spinning at ~500 RPM.
Edit: See maccopacco’s comment. I was wrong.
The velocity unit is ticks/100ms, which would make the RPM ~5000.
https://phoenix-documentation.readthedocs.io/en/latest/ch13_MC.html
Thank you for the clarification!
Ok I got it now. Thank yall.
