When I startup my Labview and choose new project, what template do I choose?:o
Start with Arcade Drive Robot - hardware or simulation
that isnt an option, here are my options:
Blank Project
Blank VI
Simple Slate Machine
Queued Message Handler
Actor Framework
Finite Measurement
continuous measurement and logging
feedback evaporative cooler
instrument driver project
labview FPGA control on compact rio
Labview FPGA Project
labview waveform and aqquisition and logging
labview realtime control
robotics project
which is it?
I’ve never had something similar to those options before, but if anything it’s because I would assume you didn’t update your labview and driverstation with the updates located here.
That means you haven’t installed everything you need for FRC.
The Kit DVD was just the start.
Now you need to apply the Updates on this page: http://www.usfirst.org/roboticsprogr…ical-Resources
[LEFT]LabVIEW Utilities Update](http://joule.ni.com/nidu/cds/view/p/id/2262) (required for all Teams)
LabVIEW Updates](http://joule.ni.com/nidu/cds/view/p/id/2261) (only for Teams programming in LabVIEW) [/LEFT]
P.S.
I like the page that Cyrus posted.
That’s not the FRC startup window.
Go to Tools -> Choose Environment
then you should get the choice shown in the first attachment below.
Pick LabVIEW for FRC and click the box to Make this my default setting, then Apply.
We normally see the second attachment:
i click on the shortcut, Labview 2012. it sais launch labview, i click. the page i posted comes up
Did you install the FRC LabVIEW updates linked in the earlier posts?
Does *Tools -> Choose Environment *show you any choice other than LabVIEW?
yes
wait, its looking normal now, it just didnt register the updates, i installed them like 30 seconds ago
so which templaate do I choose again?
Under New use FRC cRIO Robot Project to start with new robot code.
Use FRC Dashboard Project if you want to start modifying the default Dashboard.
