Labview Limelight
Quick question (and yes I’ve been all over the docs. :slight_smile:) Can you get LimeLight (2) video to display on the roborio project? I get that you can send it to a browser, but I’m trying to see it on the precompiled standard roborio project. I’ve tried several ways to connect via Ethernet address and friendly name, like the axis ethernet cameras, but I keep getting http: can’t find or authenticate errors. I do get telemetry data. I’m just simply trying to see video while I’m messing with the project.
Thanks, this has really been a frustrating journey.
-A
You can set a pipeline to just video and use it. Look at the network tables section in the docs. And you can switch pipelines back and forth but there is a delay of about a second
Yup, checked out the commands, and the rest of the docs. And we can switch pipelines. However, still cannot see video on the uncompiled (heck mebe even the compiled, tho I don’t think you can see anything in that mode. heh) version of the roborio software in labview (where the target is the rio, not the dashboard). We are just looking for video. It seems that it’s doable in the dashboard, just haven’t gotten there, and we can see video on the browser windows (using the correct port addresses, typically 5801 for controls and 5800 for pure view). Just need to know if someone has gotten video on the rio targeted labview environment and if so, how? at the absolute very least, if so. :slight_smile:
In direct reply to uh…your reply, how do you use that just video pipeline in labview. I can get data but not video.
(is frustration = T, then pipe to global:belligerence)
RAWRR
(is global:belligerence = sociallyacceptable, else silentacceptance = T)
Sigh…
-A
