I try to shift from a value of 0 to 180 yet I only get a 45 degree move.
How do I take advantage and achieve the full 180 degrees of movement possible with a servo?
Any help would be appreciated.
I can get to one extreme but not the other extreme on the other side. I have values between 0 and 254. It won’t let me put in negative values which I tried to do.
Also can someone explain the Scale Servo VI to me please? I have a feeling I should be using it but am unsure what it does or how to use it to effect the servo performance.
Thanks for your help.
