LabView Problem
When I install the LabView 8.6.1 for FRC 2011 and FRC 2011 Tools and CompactRIO Drivers it seems to install fine; however, when I open up Labview it is not the FRC edition and does not have the robotics library. I did use the DVD that came with the kit. I did use the serial number it came with. Please help. Thanks.
You then need to install a series of Software Updates to get the FRC specific stuff.
After installing the software from the DVD, you must install the updates.
This is described in the Getting started with the 2011 control system document from the Kit of Parts website.
Thanks for your help! :slight_smile:
