For some reason, whenever i try to open a labview VI, The RT Compact rio Target gives an error saying “The plug-in for the selected item is not installed on your system or the plugin has an expired license. please contact National Instruments.”
Press start and launch the “NI Update Service”, more than likely you haven’t installed the updates for Labview. Then install the FIRST Software updates.
it cannot connect to the internet. its ip is configured for the robot.:yikes:
Press start, type “Network and Sharing Center”, Enter. On the left side, click “Change Adapter Settings”, Select the adapter that you would like to use to connect to the internet, right click it, “Properties”. In the list menu, choose “Internet Protocol Version 4” Then Click Properties. Change the Radio button to “Obtain an IP address automatically” Okay out of everything and connect to the wifi, or connect your internet cable.
it said there was an error connecting to national instuments
Do you have a firewall or AV on? If so turn it off, including the firewall in widows, Retry Connecting The Update Software.
kk, it worked. the problem was the PC was running at max and did not have room for data
I believe that I have the same problem except for my LabVIEW is up to date with all software downloaded.
