Labview Talon SRX
I am trying to insert an open talon srx using can. When I go to motor controllers the CanMotor folder is empty. Why is this? Do I need to install something else?
@AvKauf make sure you have the Phoenix Framework and that you are looking for the functions in the Third Party folder of the functions pallete.
I installed Phoenix Framework but it still doesn’t show up. Do I need to do something after I install it?
I figured it out.
I recommend you share your solution, so others reading the thread can benefit from it :slight_smile:
I just restarted the computer and everything worked.
