labview update problem
For some reason, when i try to update labview on my laptop to the frc 2012, everything works fine (all of the vi.lib is there) but the startup screen is the 2011 labview regular, and not frc. Does anyone know how to fix this?
We had a similar problem. This worked:
http://forums.usfirst.org/showthread.php?t=18673
After installing LabVIEW from the USB “card” flash drive, did you then install the required update that was specified in the Getting Started document?
yes, all 3 of them in order (many times might i add)
My team had the same problem. Try installing the update here:
http://joule.ni.com/nidu/cds/view/p/id/2261/lang/en
Hope that helps.
