I am trying to run a motor using a Talon srx but when I hit enable the motor starts running right away and I do my know where to look in labview yo fix the issue. Where would I look
Can you post your code here, and explain what you’re trying to get the motor to do. It will be hard to help you without knowing that.
Is the motor not running at all? Because it looks like a 0 is connected to the set value.
Can you verify that?
