Last Anvil 2024-2025 | Product Releases & Updates
Update 12/30: We can’t believe it is less than a week away from Kickoff! In preparation, we wanted to begin our first new product spotlight - Retention Bearing Hats.
Our retention bearing hats were designed in collaboration with Team 4488 who has been using a similar style for several years now. Unlike other options on the market, these are designed with an outer ring to provide teams with greater versatility on hole placement for the same cost.
As a few possible examples of added utility (provided by 4488):
(1) when prototyping, there is no need to worry about perfect 180 degree hole placement, you can just get the bolt in quickly;
(2) when polycarb gets stripped during a match, you can quickly drill and tap a new hole without having to take off the hat;
(3) when designing, belt or chain may be accidentally overlooked and a spot where you thought to place a retention bolt just no longer works, so it is nice to just be able to drill a new hole as opposed to making a new part.
To note, we also wanted to give teams better control over their purchasing decisions, so instead of offering them in packs of 2, 4, or some other quantity, we chose to sell them individually for the same per unit cost of the packs.
Photos
We hope you find these features helpful, and as always, feedback is appreciated.
Stay tuned for more spotlights.
Do you have pictures/examples of how the slots are used?
Also is the website correct that the 240* hat is lightest and the 75* hat is heaviest?
I will see if I can grab some pictures of where we used them on our previous bots when using the slots instead of the tapped holes and post them here.
Thanks Sam!
On the weights, that’s correct. The 75 is slightly heavier than the 240. However, it may depend on scale calibration. They are all approximately around 0.17 (oz).
Here is an example from this past years bot on our intake. These are a slightly different/older version of the hat collab with LAI but the red circled areas show the bearing hats there and how we had one bolt that was into the “threaded” hole but the second one we used the slot. We designed it to be for those areas were having the more “standard” degree offsets for retention just wouldn’t work necessarily or in the case of a polycarb intake if the polycarb got broken and your ideal location wasnt there anymore, you could still keep the bearing hat there and just drill a hold and put a bolt washer nut combo on there drilling in place. I can try to track down some more pictures if this doesnt answer your question.
Update 1/1: Happy New Year!
As a quick update, we wanted to let teams know that we’ve updated all our product pages to include Onshape links. We hope this will make it easier for teams to incorporate our products in their design process.
Update 1/6: Reefscape has arrived, and we can’t wait to see what teams devise to navigate the perilous depths of this year’s challenge.
For our next spotlight, we are pleased to present our Continuous (Closed-Loop) Belt Tensioners.
They are designed with the following features:
  • Adjustable mounting for versatile integration
  • 0.625" width to fit two 0.375" ID bearings (flanged or radial)
  • Easily implementation of custom rollers
  • 6061-T6 Al
  • Center-to-center slot distance is 0.5" for patterned tubes
  • Compact design for space-constrained builds
We are excited to see teams deploy these this season.
Do you have a time line to restock tge belt tensioners
Team 5675 has already used the bearing hats to help with prototyping. Very easy to work with and very quick to implement. I will have some pictures later. Thanks!
Since they were a late addition to our 2024-2025 product lineup in response to feedback, these will be available to purchase at the end of January (Week of the 20th or 27th).
We will keep teams apprised of their status. Know that we are working hard to get them to teams as quickly as possible.
Update 1/10:
Team Anvil
With the end of week one, we wanted to take a moment to recognize the last member of Team Anvil for the 2024-2025 Season Team 2847 Megahertz:
Like with all of our teams, we are immensely grateful for their participation and collaboration this year, and we are so excited to see them compete.
End Caps / Tube Plugs
Finally, as a reminder, our end caps/tube plugs (0.0625" & 0.125" thickness) are available for purchase. However, they are moving quickly, so we can encourage teams in need to pick them up.
Super excited to be part of Team Anvil! The bot is already shaping up with several Last Anvil components on it!
Update 1/13: Week two is already here!
For our next highlight, although there has been some discussion in this post previously, we wanted to focus on our Compact Open-Loop Belt Tensioners (available now) and Reinforced Compact Open-Loop Belt Tensioners (available end of January).
Features:
  • Unassembled with hardware included
  • Great for tensioning belts for belt-driven elevators
  • Compatibility with 9mm to 18mm wide belts
  • Grooved design for secure belt alignment
  • 6061-T6 Al
  • Compact size for easy integration into tight spaces
We are excited to have these in the hands of teams, and we hope both options will give teams additional versatility in form factor as well as strength.
Just paid the team a visit this past weekend, and the mech team is loving the reinforced pulleys. Now all we have to do is work down our 15+ backlog of 30T WCP pulleys…
Glad to hear that they are loving the pulleys!
