I’m currently outfitting a small machine shop. I’ve already purchased a Bridgeport vertical mill, which was a no brainer, but I’m finding it increasingly hard to determine a reliable lathe brand or even the specifications that I should be interested in.
Anyone one with an opinion or real-world experience with different lathes please pipe in and offer your two cents. Thanks a lot.
The machine shop we use has Le Blond lathes. They work very well in my opinion and have all the features, however I don’t have experience with any other brand.
I’ll start off by saying that I’m not a machinist and I don’t have a professional opinion. With that out of the way I will tell you I have used several different lathes between our robot team and where I work. I don’t know the model numbers off hand but the brands I’ve used are Acer (where I work), Jet and South Bend (robot team). I am most impressed with the South Bend and least impressed with the Jet. The South Bend seemed to be built better and is more “refined”. The Jet seemed “flimsy” (for lack of a better word) and didn’t run as smooth as the other two. Now it is possible that the other two are “lower models” in the product line than the South Bend was and may not reflect the Acer and Jet brands as a whole.
South Bend is good. Hardinge may be even better, and they also now produce and service the Bridgeport mills, if you need parts. Many modern shops still keep a Hardinge Precision Toolroom lathe around (HLV or DV models). Hardinge’s been around for over 100 years. Clausing, LeBlond and others are good.
i have used a bunch of types of lathes and most professional lathes are comperable to each other. the thing you need to look at is the price of the accessories and what is available. for example different lathes require different jaws and have different requirements when it comes to collets and so on. you will want one that has easy available parts for replacement and innital purchas. you also want to look to see if there is a taper attachment (making life much easyer), what different tail stock supports they have (drill, point, clamp, etc) all of this stuff is important.
Hardinge Lathes are the best. We use them at Utitec Inc. to machine parts to .0003" tolerences or even tighter by hand (No CNC machine could handel those jobs). Hardenge lathes last a long long long time, and they run very conecentric. In the manufacturing business Hardinge lathes are like the mercedes benz of lathes (best example i have heard from my shop instructor). We also have Harrisions which are very good lathes but as the get older they don’t hold up as well. Our Harrision lathes are probably 10-15 yrs old, brand new the tool makers tell me they were very good, now they taper about .002" if we stick a part out of a collet more than 5-6 inches. Depending on what you need to do you may not need to spend the money on a hardinge. IMO stick with the major companies (Bridgeport, DoAll, Hardinge, Harisson and… i forgot the other company)
Before it is possible to provide any informed answer to your question, you need to decide on three important pieces of information:
- What size lathe are you seeking? When you say a “small machine shop,” how small is small? Most lathes fall into three size categories: small “toolmakers lathes” (up to 10" swing, generally benchtop models, mid-size “engine lathes” (8-16" swing, 24-48" between centers, generally free-standing floor models), and “honking-big specialty lathes” (>14" swing, anywhere from 24" to 960" between centers*). Figure out the largest part you are ever likely to want to produce, then double it. That is the minimun size lathe that you should be looking for (because you will ALWAYS want to make a part that is just slightly larger than whatever your lathe can handle )
- How much are you willing to spend? If you have less than $1000 for the lathe and tooling, then we can talk about Hardinge, Leblond, South Bend, etc all day, but you are going to end up with a benchtop Taig or Sherline at best. But if you have $10,000 or more, then we can get serious and start to have some real fun suggesting brand new Clausings, or a high-end Dainichi. But reality is probably somewhere in-between.
- New or used? You will obviously pay top-dollar for a brand new machine, but with it you will get full knowledge of the work history of the lathe, and a full set of accessories and manuals. You can save a lot if you get a used machine, but you better know what you are doing if you want to avoid getting duped. Nearly perfect used lathes and lathes with 25 mils of wear on the ways will look nearly identical - do you know how to tell the difference? If you don’t know how to identify a good used lathe, or you aren’t looking to spend a lot of time (and dollars) to recondition one, then stick with a new purchase. Otherwise, be prepared to get someone who knows what they are doing to scrape the ways, re-true the bed (and maybe remove any bed twist), rethread the spindle nose, shim and recenter the tailstock, etc.
There are a couple of on-line resources that you might want to review first. Check out:
Machine Makers and Buying Considerations is a slightly dated discussion on the fine points of buying a lathe. The prices may be old, but the advice is still valuable.
Some helpful hints on selecting a lathe from Meridian Machinery. The info on this site was very useful when I was buying my lathe (a slightly used Enco 1150).
yes, that really is 960 inches / 80 feet! There are a few monsterously big special-purpose lathes out there! I know of one at the Boeing/McDonnell-Dougles facility in Huntington Beach that they use to turn the entire first stage of Delta rockets.*
From what I hear, these guys have really, really big lathes. They probably cost a bit more than Anthony’s price will allow. Heck, for the right price, those crazy guys will probably build one as big as a tractor-trailer!
When the piece of stock is 12 feet in diameter, it is not too much of a problem!
(but it is not really just a solid piece of stock - it is actually the outer skin walls of the first stage of the rocket, which is made of three isopanels, bent to shape and welded together into a cylinder; the whole assembly is then turned on the lathe to true it up as the tank end caps are welded on).
I have a picture of this bad boy somewhere. I will post it if I can find it. But in the mean time, take a look at this big Bridgeford lathe being used to turn a 20-foot auger bit.
Hey Anthony,
We currently use a Sharp-1640c lathe and a Sharp-rd-1230 radial arm drill. They are imports but for our shop they seem to be fine for the jobs we are doing. I have used them since 96 and never have had a problem. I’m sure there are better ones but for the money these have served us well. We mostly use them for fixtures and some prototype work. We use DoAll for all of our cutting needs. They make great vert/horz saws and their saw blades are reasonable also. CNC wise we use a Fadal VMC 6030 again with great results and no problems. They make smaller versions that would be great in any small shop.
Ill try to include a link to some of the Sharp machines. Like I said they are imports but seem ok for the projects we use them for.
