I understand that the field is 26’ 11.25" by 52’ 5.25", however, I am trying to find the dimensions from the edge of the field to the end of driver stations 1 and 3. I don’t know where to find the angle of the driver stations and the length of each driver station.
I need these dimensions because I’m trying to get the x, y coordinates of certain points on the field to be able to draw these in a visual simulation.
Do I have to jump around between different drawing files or is there something I’m missing on the layout and marking diagram?
The driver station diamondplate is 6 feet wide. The Loading Bay and Power Port are 5 feet and 4 feet respectively. Does that help? You know the full width, so calculating the angle shouldn’t be too difficult from that. Remember, the field perimeter can, and will, shift during play, so build with adjustability in mind.
The rules specify 20° offset from vertical (or more accurately, 110° from the side of the field). I would check this in CAD as these nice perfect angles specified by the rules don’t always mesh with reality.
