Learning Electronics
This
I’d rather get books from the public library. There are many good electronics books available over there. The only problem is that I learn something, but don’t have the parts required to validate my knowledge, causing me to fail in self-teaching electronics!
you can find components on ebay, also many manufactures will glady send you some parts for educational purposes. most IC chipsare now surface mount, so harder to test than before. Alied electronics has clearance components, sometime 100 pcs for like $2, they have a minimum order cost though.
That’s no accident. RadioShack makes their money off convenience.
For example: in northern NJ there are now basically 2 places you can go grab loose electronic parts. Wayne Electronics and Greenbrook Electronics. There used to be more. Lashen Electronics for example. However there was more money to made with telecommunications so many of the old hobby stores changed to telecommunications parts. Telecommunications parts are not like the old HeathKit amateur radios. These are not kits at all.
RadioShack takes loose, sometimes poorly quality tested parts, puts them in a neat little packaging kit and sells them at a good markup. Now if you ever need to buy quantity on those parts they’ll still try to hit you for that markup when you call Texas.
Surplus is your friend if you have no budget and need stuff to play with: All Electronics, Marlin P. Jones, Herbach Rademan, Surplus Sales of Nebraska.
Also you should find your local Ham radio clubs and if possible visit the Dayton Hamvention.
Look up your local college. See if they offer courses to high school students (I took several college courses while in high school). Look up your local vocational-technical school. If you can find the course books the college uses and buy them used at a good discount (it’s the same information after all).
Also a little business tip: since I was 9 years old (yes I worked when I was 9 in electronics mind you) I have spent a portion of my income every month on stocking up electronics. As a result I have a selection of: resistors, capacitors, inductors/transformers (and cores to wind my own), diodes, rectifiers, TTL logic, CMOS logic, MCU, CPU, motors, wires, lugs and tools that is at least as large as any hobby store had (just I don’t have as much quantity).
Don’t just rush out to buy stuff and pile it up. If you are committed to this budget yourself and have a plan.
Along the same lines of textbooks, I found a while ago this free textbook (http://www.ibiblio.org/kuphaldt/electricCircuits/)which walks you through the basics of DC, AC, Semiconductors, and Digital logic. Its a spectacular resource and also available on the android app market, just look up “lessons in electric circuits”. Although this does not solve the physical parts issue, one of the volumes of this book is just experiments that could help you apply what your reading about. Whats nice about this volume is it also explains the concept from the results of the experiment.
I want to buy the basic components to get started and build my inventory over time so I don’t have to disassemble everything I build/set up! That’s why I don’t have a Pi anymore. I have put it in a permanent place, so I just use it invisibly!
If you are having a hard time finding parts, another option is a simulator. PSPICE is what you’d use for more accurate simulations, but there are plenty of user friendly online simulators. I use this one occasionally: http://www.falstad.com/circuit/
I’ll put in another plug for reading – good books, websites, etc. Are you familiar with Kirchhoff’s Laws?
Yes. I am familiar with Kirchoff’s law! E{abs[ups]-abs[downs]}=0, where E means Sum of!
The Kirchhoff’s Laws the previous poster is referering to are the circuit laws. They basically say that all of the voltages in a loop must equal zero, and all of the currents at a node must equal zero.
That leads to the mesh-current and node-voltage methods of circuit analysis, which are fundamentals to all circuit design. Highly recommended starting point!
The ARRL Handbook is really good and should be availible at your library. It had enough theory to get you started, and then lots of projects.
What do you guys think of this? It’s probably the most thorough book I’ve looked at!
“Your session has timed out”. Dead link.
The three textbooks I used for my sophomore level courses at Purdue were Linear Circuit Analysis 2nd Ed (DeCarlo/Lin), Microelectronic Circuit Design 4th Ed (Jaeger/Blalock), Digital Design 4th Ed (Wakerly) (for ECE201, ECE202, ECE255, ECE270).
I wasn’t too thrilled with DeCarlo’s book, but the subject matter (linear circuit analysis) is very important for a solid foundation in electrical engineering. Jaeger’s book is very thorough, and very heavy. It’ll have most things you’ll want to know about diodes, transistors, CMOS logic, and amplifiers. I really didn’t touch Wakerly’s book, but that’s because the notes and labs for the class were that good ( https://engineering.purdue.edu/ece270/ ). Note that the course website is reused for each semester, so in January the content may be reset.
Hope this helps.
Sorry about that! That was the first time I used the library catalog system since they changed it up last! Here’s a link to it on Amazon!
That made the engineer in me tingle :slight_smile:
Dev,
As Joe pointed out the ARRL Handbook, even an old copy is a good book to put on your shelf. There should be several at your library. I would check out the ARRL website for other titles, all of them are pretty good. Check for a hamfest in your area. Should be one coming up soon as most areas have a midwinter fest in larger urban areas. You can pick up components for next to nothing. Bring a pack so you carry stuff home. you should be able to find little kits and lot’s of books if you just look around. ARRL retailers usually carry their book inventory to the fest.
Check out http://www.arrl.org/shop/Technical/
If you hurry, I think they are still shipping for Christmas. As Don pointed out, digital electronics are a world away from analog circuitry. RF is much different than audio, etc. Start off with basic AC and DC circuits. Learn DC first so that you can see how components function and then move to AC from there. When I went through school, DC was an entire semester and a per-requisite for everything else.
One of the standards of the industry (getting a little long in the tooth, but the basics are things that don’t really change): http://www.amazon.com/The-Art-Electronics-Paul-Horowitz/dp/0521370957
I’m going to be taking an online course from a friend teaching this:
http://contextualelectronics.com
It’s kinda pricy, but I think it will be well worth it.
