Legal Linear Actuators
Does anyone know if this linear actuator is legal?
https://www.amazon.ca/ECO-WORTHY-Actuator-Tracker-Multi-function-Electroic/dp/B01191JBVM/ref=sr_1_7?keywords=linear+actuator&qid=1551701125&s=gateway&sr=8-7
Its not the actuator that is the problem, its the motor. That motor may not be legal, and I’m 99% sure it isn’t.
Edit: Depending on your needs, a servo linear actuator could be sufficient. That one has a 100mm (4 inch) stroke, or travel. Here is similar 140mm stroke one from andymark with the same price range, you could try it here.
